freddy Posted February 18, 2008 Report Posted February 18, 2008 i wanted to know wat the stock bore on a banshee but i am more interested in knowing wat size im suppose to go bigger, ive already bored it once, so wat would the second size be considered?? thanks in advance Quote
Handyman Posted February 18, 2008 Report Posted February 18, 2008 The stock bore is 64mm...from there it goes 1st over size bore(64.25mm) 2nd oversize bore(64.50mm) and then is goes .010.-.060 over...If I'm wrong on the regular size bores I'm sure someone will correct me.... Quote
PSYKO Posted February 18, 2008 Report Posted February 18, 2008 64mm bore then the next size would be 30 over which is a 64.25mm bore. Refer to this pdf off of Wiseco's website, look under the Banshee section. http://www.wiseco.com/PDFs/Catalogs/2008/CB/YamahaATV.pdf Quote
Wildcardracing Posted February 18, 2008 Report Posted February 18, 2008 64mm bore then the next size would be 30 over which is a 64.25mm bore. Refer to this pdf off of Wiseco's website, look under the Banshee section. http://www.wiseco.com/PDFs/Catalogs/2008/CB/YamahaATV.pdf 64.25 is .020" over Quote
PSYKO Posted February 18, 2008 Report Posted February 18, 2008 64.25 is .020" over Ha! Thats what i meant :wink: Quote
PSYKO Posted February 18, 2008 Report Posted February 18, 2008 check out this thread too. http://www.bansheehq.com/forums/index.php?...mp;hl=bore+size Quote
freddy Posted February 19, 2008 Author Report Posted February 19, 2008 check out this thread too. http://www.bansheehq.com/forums/index.php?...mp;hl=bore+size thanks alot guys, youve been a big help Quote
spurdy Posted February 19, 2008 Report Posted February 19, 2008 64.25 is .020" over 64.25 mm is 0.010" over stock bore. 0.25 mm = 0.010" 1.00 mm = 0.040" 25.4 mm = 1.00" 0.040" x 25.4 mm = 1.01" I am not trying to be a dick or anything, but I deal with this conversion daily! SP Quote
