E85 or M85 is all I ever run. It's like traditional alcohol except it's a little less harmful to exposed metal, fuel lines, etc.
Plus, they sell it from a pump two blocks from my house. :thumbsup:
A guy up here in our area tried to run it and it wasn't all that impressive. Seemed like a lot of work for not much gain. If you're going to go through the trouble of setting up to use it, just use methanol or alcohol.
Methanol is my choice hands down. Its also the reason I have a second tank on my bike. lol!
E85 seems easier for the normal person to buy, because they can buy what they need. I havn't found where you can buy meth or alk in small quanities.
BigRed350x: how do you get the fuel from that tank to the carbs? do you just use the fuel pump? or is it high enough to gravity feed. I was thinking of doing something like that, but I don't want to put afuel pump on.
damn. No one else has ever messed with it. I know E-85 is like 100-105 octain and it is cheaper than race fuel. I might just have to get some and try it out.
Keep in mind you'll have to run more of it than gas...just like methanol...so suddenly the savings aren't as obvious...
I can buy methanol by VP for around 35 a can, but I'm probably going to get a 55 gallon drum delivered to my house this year....much easier....and WAY cheaper.
Screaming Yellow...you're not far from Vitos...talk to Lane. He can find Methanol for you....
E-85 is a waste of time. Makes no more power, will still eat away on the fuel lines and you get the fuel mileage of methanol and the power of 91 octane.
E85 and M85 is the same thing as methanol, alcohol, or ethanol. In fact most folks that think they are running alcohol are probably running E85 or M85 and not M100 or E100. :geek:
I'm pretty sure you know where I get mine. I know my stuff is real methanol. ROFL, I have the cancer to prove it. :laugh:
You get it from a trailer in the middle of the woods? :biggrin:
Methanol is not ethanol, but both are alcohol. Propanol, butanol, other hydocarbon chains with OH- on the end ("ol") are categorized as alcohol. Drinking ethanol will get you drunk, any of the other alcohols will likely kill you, btw.
I've read that you jet for e-85 the same way as methanol, but I have no experience w/ E-85.
