350BANSHEE350 Posted February 9, 2008 Report Posted February 9, 2008 okay so with my new bars and the way i have the front brake et up which is tilted down a little it makes the little clear glass for the front brake rezzy empty but if i jack up he frontof the bike and make it so the rezzy is level its shows full like always but the way my bars are i cant have it level so my question is, is it alright to leave it tilted i am getting good preasure on the lever what do you hink guys? i think its fine because its still full its like filling glass full of water and tilting it thats all thanks guys Quote
Bansh-eman Posted February 9, 2008 Report Posted February 9, 2008 as long a you have fluid over the plastic part where it pulls the fluid down your fine. the res does not do anythig for pressure. the piston that the lever pushes creates the pressure in the lines. just dont let it suck air and your good Quote
350BANSHEE350 Posted February 9, 2008 Author Report Posted February 9, 2008 well its full if you take the cap off, and lots goes to the pick up line will it be fine going over bumps? it will be able to swish around a bit Quote
MILO Posted February 10, 2008 Report Posted February 10, 2008 i would say that as long as it is FULL when it's level it should be fine. it's going to 'swish around' whether it's set level or not. you should be ok bud. :cool: Quote
