4stroker Posted February 7, 2008 Report Posted February 7, 2008 Hey there. I am trying to find out if a 66mm Wiseco blaster piston is the exact same piston as a 66mm Wiseco 795 series banshee long rod piston. reason i want to know is, im building a long rod motor and the jugs are on 66mm bore. im using 66mm 795 pistons but thats the biggest 795 piston wiseco make. So if i ever need to rebore it will i be able to use 66.25 and 66.5 blaster pistons? (assuming my cyls can be bored 100 thou over) thanks, mark Quote
RZBansheeMan Posted February 7, 2008 Report Posted February 7, 2008 They will work, but you will need to get the head re-chambered to work properly, as the blaster pistons have a different dome shape. Quote
