myecrip Posted February 6, 2008 Report Share Posted February 6, 2008 i am going to be powder coating my frame and i need to take out my steering stem bearing and rubber piece does anyone have an easy way of doing this. thought i would ask before i dug into it dave Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted February 6, 2008 Report Share Posted February 6, 2008 Do you have a cylmer..(banshee manual) they tell you how to remove it.. There is a tool I believe also a trick, you would have to do a search for it but you have to buy a bolt and to nuts at turn it out.... Do a search for the size bolt you will need.. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted February 6, 2008 Report Share Posted February 6, 2008 I used a screw driver and a hammer to get the retainer out.. after that I used a bearing driver to push out the bearing and seal... Socket would work too. Quote Link to comment Share on other sites More sharing options...
WinchedWolvy Posted February 7, 2008 Report Share Posted February 7, 2008 (edited) i am going to be powder coating my frame and i need to take out my steering stem bearing and rubber piece does anyone have an easy way of doing this. thought i would ask before i dug into it dave Go to autozone and get 2 30mm axle nuts and weld them together conicle to conicle then use a 30mm socket,works like a champ Edited February 7, 2008 by WinchedWolvy Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted February 7, 2008 Report Share Posted February 7, 2008 You just need a large head bolt that fits the internal nut in the frame, then thread a nut onto the bolt and tighten the two together. Stick a wrench on the bolt and nut assembly while in the frame internal nut, and loosen. Quote Link to comment Share on other sites More sharing options...
NYUK Posted February 7, 2008 Report Share Posted February 7, 2008 cotton eyed joe sells a tool. it works like a charm. Quote Link to comment Share on other sites More sharing options...
. Posted February 7, 2008 Report Share Posted February 7, 2008 Is he selling stuff? Where at? Quote Link to comment Share on other sites More sharing options...
