oneslowbanshee Posted January 25, 2008 Report Posted January 25, 2008 I Might have a deal going with an 87 frame for cheap but my question is I got A-arms and spindles off an 01 can I use lower a-arms and spindles for the 87 frame? Quote
oneslowbanshee Posted January 25, 2008 Author Report Posted January 25, 2008 WOW I would have thought this would have been answered quickly Quote
woodro77 Posted January 25, 2008 Report Posted January 25, 2008 the bottom a arms are the same off a j arm , but im not sure about the spindles , i think i heard the front brakes are diffront on the early year banshee's , Quote
RZBansheeMan Posted January 25, 2008 Report Posted January 25, 2008 The answer is yes, and there are companies out ther that sell a weld in kit for the J-arm frame to make it accept the upper A-arms Quote
Fireroad Express Posted January 26, 2008 Report Posted January 26, 2008 yes , the spindels and calipers are different on J-arm bikes. so are the front brake lines i think. Quote
oneslowbanshee Posted January 26, 2008 Author Report Posted January 26, 2008 Alright guys thanks for the replys Quote
woodro77 Posted January 26, 2008 Report Posted January 26, 2008 yes , the spindels and calipers are different on J-arm bikes. so are the front brake lines i think. thats not true , i had a 1990 j arm banshee , and i switched the spindles and brakes over to a a arm frame and everything fit perfect . but if i can remeber correctly , the 87 -88 brakes were different , 89 and 90 j arm spindles are the same as the newer a arm frames , if you look in the repair manual it tells you . Quote
