I am needing a little bit of help with some minor things on my Banshee. Is there anyone in the Lewisville or D/FW area that can help?
I can refer you to my mechanic...he does bad ass work and is cheap as hell. He resides in Grapevine. He is only charging me $250 for labor on a complete top end rebuild, cleaning the carbs and changing out my rear axle bearing. I can PM you his info and number if you wish.
does that include pistons, rings, bearings, wristpins, gaskets, boring and assembly?
Please send me his contact info. I am about to put some pipes on and will need help with jetting and then also I have the rear apart to change out the swing arm bushing but can't get the bolt out. That is the help I am needing now. Do you think he would be able to help me out? Thanks.
No, the price I stated in the earlier post was for labor only. I should have been a little more clear in my above post, thats my bad.
Grand total for top end rebuild, carb cleaning and axle bearing was $459.90....and yes its a COMPLETE top end rebuild kit from magicracing.com everything needed is included for a complete top end rebuild.
$250 Labor
$209.90 Parts
Yeah he has 25 years exp working on ATVs and dirt bikes 4 and 2 stroke and knows his shit, he used to own a shee and when I dropped mine off he was like damn I miss my old shee. I will PM you his info and when you can contact him because he works nights at DFW.
Edited by bagged93chevy
