What should the floats be adjusted to? I know how to adjust them, just need a measurement of some type. I'm pretty sure they need adjusted. I was riding yesterday for a minute or two and when I would get into it in any gear, it felt like it would run out of gas. I would sit and let it idle and it would fill the bowls back up and same thing again...
turn the carb upside down, the bottom (top of if they're upside down) of the float should be level flat.
If they're set, check one of two things, vent line plugged from the gas cap...or junk in the screen of your fuel valve...
I pulled my hose off of my petcock and watched it flow, it flowed a full stream and didn't stop untill I shut it back off. I'm really thinking that my floats need adjusted. I got halfway into it today and had to quit and go to a birthday party. I'll check them out and hopefully rejet it while I'm in there too.
