I was under the impression that a stock stroke 65mm cub runs with the same 65mm wiseco piston that one use in the oem cylinders, is this true or not? Can someone please confirm this for me.
Thank You
thats a good ? ... i was just thinking that the other day. my stock cylns are bored .40 over... i believe that is a 65mm piston. if so, is that whats run in a cub ?
If it's the 110 mm rod, yes...
As JT said, 115 rod needs the 795 series for smaller bores, blaster pistons for the bigger bores.
And...to add...whom ever you are getting your head/domes from needs to know you plan on using a banshee or blaster piston..the crowns are different. They also need to know if you're running gas or methanol...
