meanv10 Posted December 13, 2007 Report Posted December 13, 2007 If you put one of these on your banshee do you have to change the jets? Quote
meanv10 Posted December 13, 2007 Author Report Posted December 13, 2007 how hard is it to do and is it worth it my banshee is all stock. thanks Quote
zach45 Posted December 13, 2007 Report Posted December 13, 2007 (edited) u put pipe with the kn you will have a whole diffrent bike.. i dono with just a kn.. Edited December 13, 2007 by zach45 Quote
meanv10 Posted December 13, 2007 Author Report Posted December 13, 2007 doing jetting, is it easy? Quote
zach45 Posted December 13, 2007 Report Posted December 13, 2007 yea... do a search you will find plenty on it.. Quote
meanv10 Posted December 13, 2007 Author Report Posted December 13, 2007 thanks just bought one off ebay for 40 bucks, that a good deal? Quote
zach45 Posted December 13, 2007 Report Posted December 13, 2007 the pro flo plate and th kn?? think thats what i paied.... there around 90 new.. so yea.. go to local car store(pep boys autozone) and get the recharge kit Quote
Screaming Yellow Zonker Posted December 13, 2007 Report Posted December 13, 2007 Air filter Remove snorkel:1-2 sizes larger on the mains, adjust airscrews Remove airbox lid:1-2 sizes larger on the mains, adjust airscrews Add foam air filter:0-2 sizes larger on the mains, adjust airscrews Add K&N air filter:4-6 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add 2 into 1 Foam air filter OR dual carb-mounted foam filters (removing entire airbox, NOT in addition to removing snorkel and airbox lid above):2-4 sizes larger on mains, adjust airscrews, add one size on pilots if necessary Add Dual K&N carb-mounted air filters (no airbox, NOT in addition to removing snorkel and airbox lid above):4-7 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add Outerwear:no change Add TORS elimination kit:no change Quote
meanv10 Posted December 13, 2007 Author Report Posted December 13, 2007 so about 5 sizes on both carbs and then adjust the air screw right? I know you turn it in or out but how do you know what the right setting is? Quote
TJ10 Posted December 13, 2007 Report Posted December 13, 2007 so about 5 sizes on both carbs and then adjust the air screw right? I know you turn it in or out but how do you know what the right setting is? Take a look at this site (jetting) It will tell you all you need to know about Banshee carbs. Quote
meanv10 Posted December 25, 2007 Author Report Posted December 25, 2007 Quick question will a Raptor rear hub fit on a banshee? Quote
ClimbAnyHill Posted December 25, 2007 Report Posted December 25, 2007 Quick question will a Raptor rear hub fit on a banshee? I sold 4 rims to my friend with a 700r, they bolt right on & assume the splines are the same! Quote
meanv10 Posted December 27, 2007 Author Report Posted December 27, 2007 Anybody know what size the water pump oring is on the inlet of water pump, that the clutch cover has to slide over? Also the guy selling the hubs said that he thinks the bolt pattern would be smaller on raptor hubs, Is that correct? Quote
Michael Jackson Posted December 27, 2007 Report Posted December 27, 2007 (edited) screaming yellow that is some bullshit information you are giving out sorry bro... 4-6 sizes larger on the mains and one size up on the pilot for adding a k&n filter and takin the lid off!?!? thats crazy... the raptor hubs use the same bolt pattern, wheels are the same... but the hubs are not interchangable between axles i dont think , i think the yfz and raptor are interchangable now, the old raptors, blasters and banshees were interchangeable i believe Edited December 27, 2007 by Michael Jackson Quote
