i would use a wiseco, they are the best in my opinion, pro x seem to be ok, never ran them but my buddy does, i would stay away from vitos, have seen a lot of them go bad (broken skirts)
i wanna change because wiseco some piston the ring turn and broke the cylinder that hapen to u??? i think is a piston problem the small pin go in the piston and then the ring turn and wen it come to the exaust port .......
if ring spins it is because bore/piston clearance is to great.
Either from bad bore job (bore should be to the .ooo (thousandths), or from wear
Go with wiseco, micrometer bore, and then buy pistons for application, then bore after pistons are micrometered
