pitbike26 Posted December 6, 2007 Report Posted December 6, 2007 (edited) i dont know if their is a thread like this yet but post up your setup for the dunes lets see em :biggrin: Edited December 6, 2007 by pitbike26 Quote
530grafix Posted December 6, 2007 Report Posted December 6, 2007 i dont know if their is a thread like this yet but post up your setup for the dunes lets see em :biggrin: its in my sig. below :thumbsup: Quote
pitbike26 Posted December 7, 2007 Author Report Posted December 7, 2007 (edited) one question whats a coolhead and what does it do??? Edited December 7, 2007 by pitbike26 Quote
530grafix Posted December 7, 2007 Report Posted December 7, 2007 one question whats a coolhead and what does it do??? a coolhead increases the cooling capacity of the motor and it also allows you to change to different size domes in turn changing your compression. go to high on compression and you will need to run race gas.. Quote
bansheefreak Posted December 12, 2007 Report Posted December 12, 2007 mine is my sig.. too.. just a stock cyls 4mil duner motor.. 15/39 gearing and plus 4 swinger.. Quote
lincster Posted December 12, 2007 Report Posted December 12, 2007 This is what I drive in the dunes. Quote
KEVSWS6 Posted December 12, 2007 Report Posted December 12, 2007 My sand hill shooter My soon to be dune machine Quote
Snopczynski Posted December 12, 2007 Report Posted December 12, 2007 coolhead 19cc domes, pro circuit pipes, single pwk 35mm carb, k&n pod filter with outerwear, v-force reeds, dynoport port job, cascade heavy duty clutch, 3 stock springs and 3 toomey springs, pancake bearing clutch adjuster, rs 200w stator, lightened rs flywheel, stock bore wiseco pistons, home made double wide pegs, dual rib front steer tires, 22x11x8 10 paddle skat super lites, 13/46 gearing, +6 swingarm w/round carrier, +6 timing on the rs stator plate, maxima mtl 85w trans oil, fly quick adjust easy clutch perch, works front shocks for 180lb rider ( I weigh 165 lbs), chrome d-bar handlebars, cascade gear slammer shifter, and a hide a key in a pear tree. :biggrin: I noticed I may have a bad crank bearing, so I have to check that out, it may be getting a 4mm tz hot rods long rod crank, and 795m pistons. Quote
D|rt_BaG Posted December 12, 2007 Report Posted December 12, 2007 (edited) Does stock work for yah? Edited December 12, 2007 by D|rt_BaG Quote
rabbit857 Posted December 15, 2007 Report Posted December 15, 2007 theres mine in my sig.. I know its not a Banshee but thats in the works Quote
FireHead Posted December 15, 2007 Report Posted December 15, 2007 This is what I drive in the dunes. Is this like the time you posted pictures of some chick you downloaded pictures of off of the internet? :ermm: Quote
Snopczynski Posted December 15, 2007 Report Posted December 15, 2007 I know its not a Banshee but thats in the works You know who Dave Roberts is? Quote
rabbit857 Posted December 15, 2007 Report Posted December 15, 2007 You know who Dave Roberts is? I've talked to him on the phone and gotten parts from him before. Send me what I needed asap good guy to deal with but can be hell of hard to get a hold of sometimes. Quote
