Z0sick Posted November 28, 2007 Report Posted November 28, 2007 The wife says I can't have more than one bike, so I am selling the Banshee to buy a four stroke. As I grow older, I would like to trade a little speed for some comforts like electric start and reverse. If you have a four stroke, and are looking for a little more speed, I would like to work out a trade. I will sell it outright for $3200. Chassis: Roll Design D-Arms Ricky Stator style tie rods/ends Works Dual rate springs and shocks with Yamaha covers RAD tapered bearing carrier RAD lock nut Tusk nerfbars DG Baja bumper DG Skid plate DG glide plate DG grab bar Ohtsu 250R/400EX front tires Razor rear tires mounted on Douglas black label wheels Dunerunner front and Sand Shark rears mounted on Douglas black labels Red powder coated frame and hubs ProDesign kill switch ProDesign billet shifter Fat bars with custom billet mount custom seat to match new paint Cascade billet throttle cover Cascade brake master billet covers Cascade billet extended throttle lever Stainless Steel brake lines MSR Raptor Clutch lever PEP steering stabilizer Stock lower a-arms modified for removeable ball joint Aftermarket bronze a-arm bushings (also have a new set of Delron) Modquad slider, guide, and ball bearing rollers Modquad Billet Case Saver 55 watt lights (factory are 35) 95% of bolts/nuts are stainless steel 2 flags for the sand Engine: ProDesign cool head w/19cc domes (compression is 192 in both cylinders, stock is 130) mid-range porting stripped jugs and case cover Ricky Stator 200 watt stator FMF Gold Series pipes billet exhaust couplers FMF Power Core silencers Barnett clutch Ricky Stator timing advance plate TDR reeds on modified cages Keihin 28PWK carbs K+N filter with black outerwear billet filter adaptor Modified airbox lid billet boost bottle O-ring chain 15T front, 41T rear sprockets The bike was completely rebuilt from the frame up 3 months ago. The following pics are from before the rebuild. These pics are after the rebuild. Since the rebuild, I have taken it on 4 trips, so about 12-15 hours ride time. Quote
87sheerips Posted November 29, 2007 Report Posted November 29, 2007 Damn, Nice bike man its flawless!! Good buy for someone! Quote
