KyleMan-shee Posted November 20, 2007 Report Posted November 20, 2007 Alrightt, i'm working on putting my new clutch cable on and i noticed there isnt much room at all to work on the cable down on the lower end so ill probably just take off the carbs for some extra room. But i can't seem to get the very end of the cable out of that metal slot, is there a trick to this? I already have the handlebar side of the cable disconnected, but im a little confused with getting the lower end undone, any tips or advice on this? Thanks for your time guys, Kyleman. Quote
flattrakker Posted November 20, 2007 Report Posted November 20, 2007 Alrightt, i'm working on putting my new clutch cable on and i noticed there isnt much room at all to work on the cable down on the lower end so ill probably just take off the carbs for some extra room. But i can't seem to get the very end of the cable out of that metal slot, is there a trick to this? I already have the handlebar side of the cable disconnected, but im a little confused with getting the lower end undone, any tips or advice on this? Thanks for your time guys, Kyleman. i know when i did mine it wasnt that difficult.. fromw hat i recall... i used a screwdriver to hold back the mechanism while i unhooked the cable. Quote
inthemail Posted November 20, 2007 Report Posted November 20, 2007 i bent my mechanism. but yea use a flathead screwdriver. its like a bent metal piece hooky thing hold it back to take the tention off and stick some needlenosers down there Quote
