has anybody cut their own clutch cover gasket out of that roll of gasket material? reason i am asking is because i need a clutch cover gasket and i have a roll of that stuff laying around. should i use it or should i just wait the week to get one from my local stealership???
Why not just use Yamabond?
i never thought of that. will that really work? or are you being sarcastic?
also that brings up another question. i know some people use threebond (instead of yamabond). but i couldn't remember what stuff it was. well the stuff i got was threebond 1104 (for sealing my cases back together, that's what they gave me at the motorcycle shop) will that work or do i need to take them apart again and use something else.
also will that work for my clutch cover?
thank you to all three of you (Bansh-eman, dajogejr, FireHead) for your responses. i'm just trying to finally get this thing together so i can finally start it up.
Threebond 1104 is the same as yama or honda bond. use it for the case halfs.
Please don't use it for the clutch cover....
Gasket and any RTV....
I really don't see a porblem using it on your clutch cover as long as the sealing surfaces are in good shape and are clean. Some asshole keeps doing it to my engines and I have a had 0 problems with it. :biggrin:
