atvcraze Posted November 2, 2007 Report Posted November 2, 2007 well i started up my banshee and when i started it up its like a high piched squeal seems like its in the piston area any idea what it is. but anyway long time no talk haha been awhile since ive been on hows everyone doin? Quote
MotulMonsta Posted November 2, 2007 Report Posted November 2, 2007 You are screwed. If you haven't run your quad for about as long as you last logged on...your crank bearings got seized up. Quote
atvcraze Posted November 2, 2007 Author Report Posted November 2, 2007 You are screwed. If you haven't run your quad for about as long as you last logged on...your crank bearings got seized up. its only been about 4 weeks since i ran it or started it. any other suggestions sounds like piston is slappin but cant tell. Quote
atvcraze Posted November 7, 2007 Author Report Posted November 7, 2007 can anyone help me out here? still not sure what it is. Quote
swrbansheeboy Posted November 7, 2007 Report Posted November 7, 2007 if you pull the clutch and blip the throttle does it seem to raise with the engine rpm? Quote
atvcraze Posted November 8, 2007 Author Report Posted November 8, 2007 if you pull the clutch and blip the throttle does it seem to raise with the engine rpm? yeah thats what happens, its pissing me off but hopefully yall will help me throught it. Quote
atvcraze Posted November 9, 2007 Author Report Posted November 9, 2007 yeah thats what happens, its pissing me off but hopefully yall will help me throught it. hopefully if its something i need to repair its not an exspensive fix. Quote
91banshee Posted November 9, 2007 Report Posted November 9, 2007 did you take the stator cover off and kick it over real easy and listen ? Quote
atvcraze Posted November 9, 2007 Author Report Posted November 9, 2007 did you take the stator cover off and kick it over real easy and listen ? nope havent done that. Quote
dajogejr Posted November 9, 2007 Report Posted November 9, 2007 Does it make the noise if the clutch is pulled in or let out?? Quote
atvcraze Posted November 9, 2007 Author Report Posted November 9, 2007 Does it make the noise if the clutch is pulled in or let out?? it makes a loud noice either way if its pull in or let out Quote
dajogejr Posted November 9, 2007 Report Posted November 9, 2007 Pull the ignition cover...as said. Quote
atvcraze Posted November 9, 2007 Author Report Posted November 9, 2007 Pull the ignition cover...as said. ok ill go do that. Quote
