Suzuki Stomper Posted October 30, 2007 Report Posted October 30, 2007 I have a 400 stroker motor done by CT Racing and I have been unable to figure out the best set up. I am going to purchase the PWK33mm carbs but CT informs me that I will loose some bottom end, is this true? I am a 265lb guy and I am not sure what gears to run to make up for the loss if bottom end power with the larger carbs. I also need to figure out what chain length to run if I went to a 15/46 set up with a stock swing arm. Any help? Quote
dajogejr Posted December 5, 2007 Report Posted December 5, 2007 I have a 400 stroker motor done by CT Racing and I have been unable to figure out the best set up. I am going to purchase the PWK33mm carbs but CT informs me that I will loose some bottom end, is this true? I am a 265lb guy and I am not sure what gears to run to make up for the loss if bottom end power with the larger carbs. I also need to figure out what chain length to run if I went to a 15/46 set up with a stock swing arm. Any help? Run stock gearing...15/46 is almost the same as 14/42, stock gearing...just a hair different. If anything, go to 15/42...with the new motor, it should pull that gearing just fine. You'll be fine with 33PWKs on a ported stroker motor. The stroker will give you some bottom end and torque. Are you going to raise the compression and/or advance the timing? Both of those will help restore some bottom and midrange... Bump the compression up to 145 PSI or so, and advance the timing to +4 degrees. That should run fine on premium pump gas...and give you a kick in the seat to boot. Quote
slowpokebanshee Posted January 10, 2008 Report Posted January 10, 2008 I agree w, the recommendations, but what height tires are you running? recommend 15t front w/20 inch paddles, and 14 t w/22 inch paddles agree 15-45 sounds close to stock gearing w/your mods I would guess 15-41/42, 14-39...... Quote
