Suzuki Stomper
Contact Methods
  • Website URL
    http://
    2000 Banshee - CT Racing 400 Stroker motor - Delta V-force reeds - T6's - K&N prodesign air intake
Suzuki Stomper's Achievements
  1. You got no worries man! I raced my buddies 700 Raptor with a pipe, programer and air filter and it was no contest. Go make the Banshees proud.
  2. I have a 400 stroker motor done by CT Racing and I have been unable to figure out the best set up. I am going to purchase the PWK33mm carbs but CT informs me that I will loose some bottom end, is this true? I am a 265lb guy and I am not sure what gears to run to make up for the loss if bottom end power with the larger carbs. I also need to figure out what chain length to run if I went to a 15/46 set up with a stock swing arm. Any help?
  3. Thanks for your help man
  4. Thanks for your help. I will go buy a compresion tester today. Anyone know what the compresion should be?
  5. I was wonder if anyone else can start there Banshee with bare feet? Mine I think is low on compression but I am not sure. Is that how 2000 banshees are made or are they supposed to be hard to kick over?
