LS1Inferno Posted October 27, 2007 Report Posted October 27, 2007 (edited) I got the 87 fixed(5th gears was stuck) and i got some FMF gold series pipes, with power core 2 silencers. It has TORS eliminator. Where should i start with jetting, i live in las vegas which is like 2000 feet EDIT: everything else is stock. Edited October 27, 2007 by LS1Inferno Quote
sheerider1026 Posted October 27, 2007 Report Posted October 27, 2007 I got the 87 fixed(5th gears was stuck) and i got some FMF gold series pipes, with power core 2 silencers. It has TORS eliminator. Where should i start with jetting, i live in las vegas which is like 2000 feet EDIT: everything else is stock. i am in kentucky.. i am assuming our alt is close.. is there a head on the motor and stock carbs?? i would throw a 270 or so in it.. just my 2cents Quote
black sunshine Posted October 27, 2007 Report Posted October 27, 2007 Stock air filter with lid? If so, start around 270 like sheerider said and visit FASTOYS on here, he has a link to a plugchop in his signature that will help you out immensely!!!!!! Quote
LS1Inferno Posted October 28, 2007 Author Report Posted October 28, 2007 Yep EVERYTHING else is stock(for now). Ill se what i can do about the jets. It seems fine, The FMF website says starts with the 260 and the needle in the 3rd position i dont know what its at know. Thanks for your input. Quote
black sunshine Posted October 28, 2007 Report Posted October 28, 2007 Especially if you are going to do other mods, you will benefit greatly from doing a proper plug chop. It is the best way to tell if you are jetted correctly and all it costs is 5 bucks for a set of plugs to wreck. I went from stock 200's to 330's with my fmf's and a K&N without the lid. I stuck 300's in off the bat and it screamed but if I hadn't done a plug chop my motor would have siezed in no time. It also ran better getting the correct amount of fuel, go figure! Quote
