13bturbofc Posted October 25, 2007 Author Report Posted October 25, 2007 OK guys thanks for all the help i got my headlights and handlebar light/run switch today went out to hook them up and found the harness was not cut in fact its mint :biggrin: so i plugged the lights in and went to plug the handlebar switch in and here they have a piece of wire jumping 2 wires so you cant plug it in.. now from factory on the switch harness it has the main square plug then a single wire with a spade connector on it.. they have that spade connector on the bike side of the harness spliced right into the ignition instead of the run switch so... they have this thing setup for the kill switch that you hook to your wrist if you fall off so there is no factory run/light switch.. id like to keep the switch that they have on there but i want a functional headlight switch and i don't care if the factory run switch works.. can anyone help me with what i need to do sorry i just read over this and its a little confusing lol i hope someone understands it Quote
13bturbofc Posted October 29, 2007 Author Report Posted October 29, 2007 ok well i got everything pluged in and hooked up the kill swith works but the lights wont turn on.. any ideas? Quote
Snopczynski Posted October 29, 2007 Report Posted October 29, 2007 you need to at least take a test light and check for voltage at the various points in the system With the headlight switch off , does the taillight come on? Does the taillight come on with the switch on? Quote
13bturbofc Posted October 29, 2007 Author Report Posted October 29, 2007 you need to at least take a test light and check for voltage at the various points in the system With the headlight switch off , does the taillight come on? Does the taillight come on with the switch on? the tail light is actually always on when its running is that normal? Quote
Snopczynski Posted October 29, 2007 Report Posted October 29, 2007 No its not normal. Take the tape off the harness where the yellow wire from the stator goes into it ands see if you have a cut wire sitting there. It sounds like they just ran the yellow to the tail light and cut it out of the headlight switch circuit. Quote
13bturbofc Posted October 29, 2007 Author Report Posted October 29, 2007 No its not normal. Take the tape off the harness where the yellow wire from the stator goes into it ands see if you have a cut wire sitting there. It sounds like they just ran the yellow to the tail light and cut it out of the headlight switch circuit. ok ill check that out tommorow and get back to ya thanks for the input Quote
13bturbofc Posted October 30, 2007 Author Report Posted October 30, 2007 i got them working where the run/headlight switch connects to the body harness it was a bad connection Quote
