bombedbanshee06 Posted October 8, 2007 Report Posted October 8, 2007 The shee is becoming real hard to start latley what could cause this i have cleaned the carbs out and it was ok after that went to take it out for ride and it would not start (only its pushed started),my thought is that im oilling the filter up to much and its suxing in the oil , could this be the problem of is somthing else im mite check the reeds and see if 1 is open a little as well any info would be grate CHEERS IAN Quote
fitz18 Posted October 8, 2007 Report Posted October 8, 2007 The shee is becoming real hard to start latley what could cause this i have cleaned the carbs out and it was ok after that went to take it out for ride and it would not start (only its pushed started),my thought is that im oilling the filter up to much and its suxing in the oil , could this be the problem of is somthing else im mite check the reeds and see if 1 is open a little as well any info would be grate CHEERS IAN Did you check compression? Have you got spark? Are carbs installed correctly? Choke tube? Correct carb caps on ccorrect carbs?...Half moon section should be at rear of bike. Just some things to check. I have to kick mine 5 times with key turned off and switch at off then turn both on and she starts right up. :biggrin: Quote
