i was at my local atv shop today. owner has put together of 421 4mill cub motors, he was working on a bike today that was a 435 4mill...... he said u an order them like that. is anyone running a 435 4mill ?
i guess i'll call and ask him what it is..... he said it was the biggest before you had to trench it,i guess as in trenching ur cases???? but then that wouldnt be a 4-mill ??? i'll call tommorow, and get my story stait....and post what it is .
yea you might want to find someone else to do business with.
Trinity will get you just about any size of piston you want...
cases aren't "trenched" for bigger bores, they're machined....
Cases are trenched for cranks with a longer stroke than 4 mil...so the lower rod doesn't scrape.
You can get cubs with the nikasil, which I'd have to say is hands down the favorite, or unplated to accept a sleeve.
Once you go bigger than 68 or 70...you do have to machine the cases for a bigger bore.
I don't know of anyone running a 70mm piston, but I know the super cubs are 72mm, and the cases have to be machined to accept the bigger bore...
With sleeves, anything is possible...:)
It wasn't a cub but my stock cylinders had BB sleeves and I could bore them to 70mm
ok ,called and asked..... 69mm lightened piston, it is a cub cyln. it only takes a trinity head( not centered up )..... local guy said there's only about 10 out right now. you have to get threw trinity. port timing and everything else the same.
Calvin @ CP has been known to make a few odd ball cylinders to compete with certain size requirement classes for organized racing, my guess is this one fits in a 450cc and under class...I think a 7 mil is JUST over that, as is a 10 mil.
yes a builder can bore the cubs to a 69 mm bore,when i send my cyls to lynn at lc performance he asked if i wanted to go a bit bigger[69 bore]i said no cuz the only place that would have that size piston was going to be trinity.i also for some reason think that 68 bore would be more reliable than a 69.also i think a set of 69 mm pistons are like 220 or oround that price range. :banghead: :yucky:
Yea but a 7mm would be a 443.Then a 10 would be 465.Maybe he stuck a sleeve in it :shrug:
