  • Replies 64
  • Created
  • Last Reply
Top Posters In This Topic
I E-Mailed ASR with pictures of how my top arms were put on and he said they were on the correct way. Take it for what it's worth!
okay guys I sent ASR acouple pics of my setup to see what was going on and this is what they said
From: [email protected] Add to Address Book Add Mobile Alert
Date: Sat, 6 Oct 2007 20:43:37 EDT
Subject: Re: (no subject)
To: [email protected]
PS Make sure you set it up with 4 to 5 degrees of positive caster. This means the top arm trails behind the lower a-arm. When you look straight down at the Big Collar on the spindle side of the arm, you should see the entire top collar and the front 1/2 of the lower one when adjusted right. Any questions, just give us a call next week.
The big swoop goes on the back just as you have it mounted. It is done that way for shock clearance.
I was thinking the same thing..the ones that I have are new, They are the PSP, There could definately be a difference between new and old...I say what ever way you can get them to fit fuk it...
Ok this should make it simple. Look at the threaded part of the a-arms where the ball joints thread in at. they should be slightly slanted towards the back of the quad if looking directly down on the installed a-arm. This goes for almost every a-arm iv seen for a banshee.
Just confused now, which way did asr say was right?
Hitman look at my pics.. ASR told me that I had it correct...
Date: Sat, 6 Oct 2007 20:37:58 EDT
Hello! The big swoop goes on the back just as you have it mounted. It is done that way for shock clearance.
ok yeah looks right becuase of the 1" forward do the shock mount should be 1" back and the upper need to clear the shock
this may be a stupid question but, how do you determine left to right? when you are on the bike or when you are standing infront of the shee looking at her? Only because in your pic the a-arms are labeled... im alittle confused. lol
