I figured I would post this in here.
broke
RZ top end with electronics. I think it's on it's first overbore, I can mic it when I tear it apart. 4mm 12 port by Passion. It has never been dyno'd but I would figure on it making around 70hp, but it's a very broad powerband with the powervalves. Head is cut for 110. I'm sure I can get specs on the motor if buyer would like to know them. All seals and guides were fresh when the motor was built, around 10 hours of ride time. $800
4mm trued and welded crank, 10 hours $350
Quick change clutch cover $150
RZ shift forks and drum with Banshee trans $250
32mm lectron carbs set up for gas $400 with Prodesign intake manifolds.
Chrome Rockets $400
I will try to get pictures of everything as it's removed.
Frame with steering stem, Lonestar clamp, Airbox, nerf bars and front bumper. $1200
A-arms $400
Front shocks $650
Swingarm $400
Rear shock $500
$3000 for all
$3500 with brakes, spindles, axle, front/rear hubs, Anitfade brake hub and sprocket hub.
