Well I think I need some bigger Jets as of know I have 270 main and 25 pilot.The 270 are what came with the pipes.Mods include 20cc domes,boost bottle,fmf fatty pipes,i have dual kn pods, but i'm going to put the stock air box in with aftermarket filter because i'm going to be doing desert racing.I live in soutern california and the elevation is about 1200. Your help is greatly appreciated... Thanks
No one can help me out on this or what...
OK guys I'm new to this site and I'm definitely not tring to start anything,but I have come here to get help from the banshee enthusist and apparently no one wants to help me out and i think it kind of sucks. I can ride tell I get this problem figured out. So once again any help would be greatly appreciated. Thanks
you probably need to go up on the mains as 270s are what came with the pipe and they are intended for a stock bike with an airbox. your running k&N pods which'll need more fuel so if you stay with the pods, I'd say go to a 300 and see how it performs there, if you go to the stock airbox, then try a 290. Also, I'll add that very rarely do the "supplied" jets work perfectly, they're a "guesstimate" for trial purposes mostly. With fatties and mods similar, my bike used a 310 with an airbox. So, I'd try a 290 or 300 and see how it reacts.
Thanks you guys for the replys and good direction.I added the top notch cool head with 20 size domes and the boost bottle along with adding boyseen pro reeds to the stock cages.Then i'm adding the stock air box with a aftermarket filter.These are the mods I have done to give her a little make over.I was also wondering if I need to change the pilot to 27.5 like I have seen in some other post. Thanks
It use to start up perfect until last october at dumont. I had just left camp and one of the slides got stuck wide open towed it back gave the carbs a nice cleaning and now it's a bitch sometimes to start..I might not have them sync together enough..I basically look through the window in the sides of the carbs and got the holes in the window matched up.If you have any sync ideas that would be great. Thanks
Slow your roll, homie...
You gave people 24 hours to respond...no one here is on call, some people actually have to work, too....
There are plenty here to help...just have to be patient a little bit....
270 with pods is way too lean...you're gonna pop that motor as said.
If you plan on running the air box with no lid, 280 to 290...
If you're gonna run a lid, I bet it'd be fine with 270 in there....
With that much desert riding, be sure to get an outerwear to filter some of the dirt/dust you're gonna encounter, they do keep your filters cleaner longer.
Jeff @ FAST sells a tool called a sycrometer. You'll probably have to remove the airbox to sync the carbs, but it will get your sync spot on....
http://www.farmandsandtoys.com/partdetail.asp?partid=59
First of I'm not your homie and if you read it correctly don't take it personal..I'm new here and i'm kind of ancius about ridding my bike.I have put alot of time in to building front suspesion along with alot of other things.And the work comment oh come on I do have lunchs and breaks and if thats you in the picture then looks like you sit at a desk all day while I'm a machinist.I build plastic injection molds and build trucks part time my friend so please don't ever bring up work to me.........WWW.STGEORGE-MOTORSPORTS.COM take care.....Sorry if I affinded anyone take care.....
Dude, you just snapped on one of the most informative and heplful guys on this site..... way to make an impression!!!!!! :down:
You're right...you're not my homie. Nor are you someone I care to help anymore...with your piss poor, poor me bleeding heart sob story.
I can understand about being anxious about riding your bike...I go weeks on end and have a TON of money poured into mine...that doesn't give you the license to be a dick...
Good luck...
Good luck...
lol....THREAD OVER
