hey all
just a quick jetting question
what jets should i have.
im at sea level, run in 104 to 122 degrees farhenheit (40 to 50 degrees celcius) and dont have the airbox lid
other than that its sadly stock
My wife has an 06 banshee stock and it has a prodesign K&N kit installed lid off and plug chop was perfect with the 200 main. At 220 it bogged out in 5th gear during the chop. I ride in Florida very humid and 85 to 100 degrees 90 percent of the time. Hope this helps.
If your not running a airbox lid put some 220 or 230 in. :thumbsup:
Also, if you not running a air box lid you should get a pro flow kit and K&N filter. The stock filter setup sucks.
Or get some pod filters and outerwhere if you dont ever ride in wet weather.
