Hi,
Im new
Long story short I let a buddy take the SHEE for the weekend and when I got it back the pod filter was off on the left carb!!! I looked in the carb and it was nasty! I puld the carb and it that was not good at all! (lots of dirt) So I pulled the plug and that didnt look good!~! I did a compression test and well.......not good (98) the right has (132)
So I looking for help on the next step......well after I put my foot in my buddys ASS!
I dont want to any more damage!
Or is it safe to say I need a top to bottom rebulid?
Thanks and This site as saved me tons of time and money!
I thank you for any help or Info :down:
I'd do a top end rebuild..just to be safe.....I'd also clean out the carbs and double check everything just to be safe.....I'd put both of my feet in my buddies ass if he did that to me...is he going to hel with the repair costs??
Your going to have to pull the motor and split the cases. All that dirt also is on the crank and in the berings. Hopefully you still have a good crank. Probably not but it is a shot in the dark.
Thats what I thougt.
Well I have some work to do!
This is my first bottom end job
Any tips will help
And it is hard walk with my buddys ass stuck on my boot!
If it sucked enough in to drop the compression 30lbs i would split the cases and clean them real good.. Just seems like something that has the potential to haunt you in the future, if you neglect to do so..
edit:oopps, didn't see that you already got the awnser :D
Edited by Lethaface
