shee4speed Posted September 9, 2007 Report Posted September 9, 2007 Okay,so I removed the clutch and the shifter lever mechanism and removed the screw in the center of the shift star and it wont come off. Should it just pull off? :: Quote
Bansh-eman Posted September 9, 2007 Report Posted September 9, 2007 so you have removed everything in front if it and its just stuck on the end of the drum? not stuck like its hitting somehting right? if its not hitting anything then you just have to pull it off. it probly wont b ez to remove...but dont go prying the shit out of it.... fid a small rubber mallet and tap it... Quote
shee4speed Posted September 9, 2007 Author Report Posted September 9, 2007 Okay, I will go give it a whirl. Quote
shee4speed Posted September 9, 2007 Author Report Posted September 9, 2007 Man, I dont know how to get behind it it tap it off. Any ideas? Quote
Bansh-eman Posted September 9, 2007 Report Posted September 9, 2007 you probly dont need to get behind it... just hit it around the edges and on th front and jar it loose Quote
shee4speed Posted September 9, 2007 Author Report Posted September 9, 2007 no luck.Any suggestions? Quote
shee4speed Posted September 9, 2007 Author Report Posted September 9, 2007 Okay got it off.For anyone interested,took a piece of wire and wrapped around and it pulled right off. :biggrin: Quote
Bansh-eman Posted September 9, 2007 Report Posted September 9, 2007 you made a loop and pulled outwards and it slipped right off? thats odd that you couldnt tap it and break it loose but the wire pulled it off lo.. oh well at least its off now Quote
