91banshee Posted September 3, 2007 Report Share Posted September 3, 2007 has anyone ever had a set of cases chromed , polishing is just to much work and dulls out quickly . yea i know the saying chrome wont get ya home but looks good pushen , but man it looks good Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 3, 2007 Report Share Posted September 3, 2007 has anyone ever had a set of cases chromed , polishing is just to much work and dulls out quickly . yea i know the saying chrome wont get ya home but looks good pushen , but man it looks good Chrome would be fine if you mask everything off properly (read: alot of work). The other issue, however minor, is that chrome acts as a thermal barrier which can slow down the heat rejection from your cases. If you need chrome work done I can suggest someone to do it. Polishing and a clear coat might make more sense. :geek: Quote Link to comment Share on other sites More sharing options...
NYUK Posted September 3, 2007 Report Share Posted September 3, 2007 pc them. a plater will charge you a mint to do all that hand polishing. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted September 3, 2007 Report Share Posted September 3, 2007 You could just have them do the top case, really no point in doing the bottom. I just polished it and also polished the upper front and back lips of the bottom case. Really not bad at all, one of my easier projects. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 3, 2007 Report Share Posted September 3, 2007 PC them baby....just tape off holes/areas you don't want PC'd... Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 3, 2007 Report Share Posted September 3, 2007 PC them baby....just tape off holes/areas you don't want PC'd... ............make sure you remove the tape before putting the powder coated part in the oven though. :thumbsup: Quote Link to comment Share on other sites More sharing options...
91banshee Posted September 4, 2007 Author Report Share Posted September 4, 2007 Chrome would be fine if you mask everything off properly (read: alot of work). The other issue, however minor, is that chrome acts as a thermal barrier which can slow down the heat rejection from your cases. If you need chrome work done I can suggest someone to do it. Polishing and a clear coat might make more sense. :geek: thanks for the info , i didnt think about the aluminum not beaing able to trasfer heat as well , i think im gona polish the top and the clear coat it Quote Link to comment Share on other sites More sharing options...
quickbansheeman Posted September 4, 2007 Report Share Posted September 4, 2007 when you chrome out aluminum, after a while the chrome starts to peal off, i would polish instead or pc. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 4, 2007 Report Share Posted September 4, 2007 (edited) when you chrome out aluminum, after a while the chrome starts to peal off, i would polish instead or pc. thats not always the case, if you have a quality chromer do the alum they will last just as long as any other type of chrome.when they peel its because the mtal was not preped well. the guy that firehead is talking about can give you the down and dirty on it... Edited September 4, 2007 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 4, 2007 Report Share Posted September 4, 2007 when you chrome out aluminum, after a while the chrome starts to peal off, i would polish instead or pc. This is only the case if the prep work on the part was done in a crappy manner, thus allowing the part to begine to corrode before the chroming process begins. :geek: Quote Link to comment Share on other sites More sharing options...
bk_banshee Posted September 10, 2007 Report Share Posted September 10, 2007 has anyone ever had a set of cases chromed , polishing is just to much work and dulls out quickly . yea i know the saying chrome wont get ya home but looks good pushen , but man it looks good Sides case Covers sure no problem. Cases, could be done but hoesntly I don't tink I would do it. Top case half could turn out nice but the lower half has all those tight spots where it is hard to polish and hard to get chromed. Second, during to steps of the 24 dip process there are two chemicals that do some small etching for the electrolis nickle and chromate to adhear properly. This would be a potential problem to your bearing surfaces. A set of cases would run around $300 - $450 depending on the condition. Cast aluminum does not chrome very nice without a crap load of polish time. IMO - Powdercoat them. Quote Link to comment Share on other sites More sharing options...
