99Banshee Posted September 1, 2007 Report Posted September 1, 2007 Got the shee running but now when you give it gas all it will do is bog out.. Any idea's of what the problem is.. Buddys shee has been broke down for 3 months now.. Quote
paulnyw Posted September 1, 2007 Report Posted September 1, 2007 mine did the same thing check your parking brake switches or you may have dirty jets Quote
Toomey Banshee Posted September 2, 2007 Report Posted September 2, 2007 Did you unplug the tors and the parking brake, clean the carbs? My guess thats where the problem is. Quote
bansheefreak Posted September 2, 2007 Report Posted September 2, 2007 check your choke tube between the carbs make sure its on.. and also check make sure carbs slides are in there right carb.. Quote
sa3ood_banshee Posted September 2, 2007 Report Posted September 2, 2007 (edited) does it bog all the time,(even when the bike is warm) if it bogs when the bike is warm: i think u should check the jetting or clean the carbs if it only bogs when cold,then idles fine: its carboned he will have to drive it W.O.T , but first make sure its not a jetting issue so u wont repent later ,:thumbsup: sa3ood Edited September 2, 2007 by sa3ood_banshee Quote
dragbanshee Posted September 6, 2007 Report Posted September 6, 2007 (edited) Got the shee running but now when you give it gas all it will do is bog out.. Any idea's of what the problem is.. Buddys shee has been broke down for 3 months now.. my 97 was doing same thing, my floats were way off and one pilot looked to be clogged. Edited September 6, 2007 by dragbanshee Quote
