g_low0885 Posted August 28, 2007 Report Posted August 28, 2007 i know some one posted a while ago on where to get one. i have used the search and did not have any luck. i have looked at jegs thet have them there but i am not sure witch one i need. does anyone konw the lbs. of pressure for the cap? Quote
Snopczynski Posted August 28, 2007 Report Posted August 28, 2007 Its a 16 psi Mr. Gasket radiator cap. I think Summit has them. Quote
grounded Posted August 28, 2007 Report Posted August 28, 2007 After seeing this post , I went to jegs and ordered one. I was going to do an in-line gauge , but really wanted a cleaner install. Anyway , this is the one I got: http://www.jegs.com/webapp/wcs/stores/serv...amp;showValue=1 Quote
Justintoxicated Posted August 28, 2007 Report Posted August 28, 2007 I knew I should have got red. Guage is kinda cheap I probably should have sprung for a quality liquid filled gauge. Oh well this was easier with fullbores. Quote
FireHead Posted August 29, 2007 Report Posted August 29, 2007 I knew I should have got red. Guage is kinda cheap I probably should have sprung for a quality liquid filled gauge. Oh well this was easier with fullbores. Can you post a picture of it installed with Fullbores? :geek: Quote
Snopczynski Posted August 29, 2007 Report Posted August 29, 2007 Firehead, whats your angle with this picture thing, you keep asking for one? There was a pic of one with fullbores in the other post that I started? Quote
xXBlessedWithDeathXx Posted September 21, 2007 Report Posted September 21, 2007 (edited) Just for a heads up my cap is filling with antifreeze same as my buddy. this could be a good or bad thing. its not leaking out so thats good and if it fills and dont leak thats better but i figured i would post a heads up. i`ll have pics after the weekend to get more in it. its filling very slowly but its visible. Edited September 21, 2007 by xXBlessedWithDeathXx Quote
jbooker82 Posted September 22, 2007 Report Posted September 22, 2007 you got the liquid filled version :biggrin: Quote
Snopczynski Posted September 22, 2007 Report Posted September 22, 2007 It comes with water in it. I suspect if you inspect the sensing bulb at the bottom you will find a hole. Quote
peterlocal22 Posted September 22, 2007 Report Posted September 22, 2007 esr has a real sweet gauge i just bought. its a super clean install too. i located in the second vent on the right by my gas tank. all i have to do it lean alittle to the right and there it is. its liquad filled too and seems like a real nice make. Quote
xXBlessedWithDeathXx Posted September 24, 2007 Report Posted September 24, 2007 (edited) It comes with water in it. I suspect if you inspect the sensing bulb at the bottom you will find a hole. nope never had water in it and we got them new. i cracked the D-arms and i didnt ride much so i have no pics yet. like i said some watter but not much. i figure by winter it will be full and look nice if it dont leak. Edited September 24, 2007 by xXBlessedWithDeathXx Quote
Snopczynski Posted September 24, 2007 Report Posted September 24, 2007 Well, mine had water in it when I got it. Most of them do, thats how the bulb makes the gauge move. Quote
Justintoxicated Posted September 24, 2007 Report Posted September 24, 2007 Well, mine had water in it when I got it. Most of them do, thats how the bulb makes the gauge move. Mine does not have a drop of water in it, it is not a liquid filled gauge. Not sure what bulb your talking about. No pics yet, No Motor in the bike... Quote
Snopczynski Posted September 24, 2007 Report Posted September 24, 2007 the bulb is the portion that hangs down into the radiator on the bottom of the cap. It looks like a copper tube with the end closed up. Quote
