4stroker Posted August 27, 2007 Report Posted August 27, 2007 hey guys a buddy of mine has an 01 banshee with the following mods: Noss machine head 19cc domes FMF sst pipes and silencers 32mm mikuni flat slides pod filters clean up port and cases matched to barrels recently got jetted/tuned on the dyno and it only pulled 44hp at the tyres i wouldve thought it would make alot more than this? this weekend we are going to install a timing plate (set it at +4) and v force 3 reeds. do you think this will get us a couple more hp? also would he benefit much from going to 18cc domes and running aviation fuel? have a buddy with a helicopter so its no problem lol.. are Noss machine domes the same as pro design domes etc?? thanks, mark Quote
jbooker82 Posted August 27, 2007 Report Posted August 27, 2007 Yes noss machine domes are the same as pro design. Deffinatly do the timing plate. Reeds dont really add hp. Might help out a little. Reeds makes the banshee more snappy on the throttle. Better throttle responce. Bumping up the compression will add more power in the mid range. You should do a compression check to see what psi your at now. Install the gauge, hold the throttle wide opean and kick until the needle quits moving. You can run about 150 psi on 90-91 octane fuel. If your wanting more power then you need to do a real port job not just a clean up. Quote
4stroker Posted August 27, 2007 Author Report Posted August 27, 2007 yeah hes not exactly chasing numbers we just thought it wouldve had more thats all got some reeds cheap and the timing plate is easy so we thought wed try those couple of things, switch to 18cc and run race gas coz we can get it for the same price as pump fuel. should wake it up i reckon Quote
tonyown Posted August 27, 2007 Report Posted August 27, 2007 What about the crankshaft? is it trued/welded? I think high compression on stock crank isn't a nice idea Quote
4stroker Posted August 27, 2007 Author Report Posted August 27, 2007 it actually has a wiseco hot rods crank in it, are they trued welded? i didnt list it as a mod coz its just standard stroke etc.. Quote
XxMeltIcexX Posted August 27, 2007 Report Posted August 27, 2007 What about the crankshaft? is it trued/welded? I think high compression on stock crank isn't a nice idea You dont have to get it welded, but i guess is a good idea... Many people on here run 150 -185 psi on stock cranks not welded (I run 185 on a stock crank, unwelded and i run my shit), When it happens it happens and that means i have to add faster stuff while its torn down :biggrin: Quote
Bansh-eman Posted August 27, 2007 Report Posted August 27, 2007 You dont have to get it welded, but i guess is a good idea... Many people on here run 150 -185 psi on stock cranks not welded (I run 185 on a stock crank, unwelded and i run my shit), When it happens it happens and that means i have to add faster stuff while its torn down :biggrin: what size domes are you running that u clam to be at 185 psi in a stock crank? Quote
XxMeltIcexX Posted August 28, 2007 Report Posted August 28, 2007 what size domes are you running that u clam to be at 185 psi in a stock crank? 18cc domes, 3000 ft. Quote
