my banshee locked up and in the process of rebuilding live in ms because of the heat im putting on a cool head i bought it with 19cc domes but dont know if there the right size for my quad the spec are i run 92 octan with klotz racing 32:1 .40 over with stock size crank and wisco pistons dont know if sea level counts but gulfport,ms is below sea level its jetted with the t5 but now im in ms and below sea level dont know if i have the best jets any info would be great or any web sites that have good specs would be great
19cc will be borderline for 50/50 race gas. Its gonna depend on your bore size and squish. Put the 19cc domes in check squish and compression and then report back.
what would be the right size to run off 92 octane and .40 over i have to much money in it for border line ill by a differant size another person said to get 22cc
you would be definitely safe with a 20cc, but you can make it with about 160-165 psi compression. Usually thats borderline 19cc domes at sea level with .040" squish clearance.
thanks for the advice im going with the 20cc just to be safe sould be done with it all by next weekend ill let u know how it went
