I have a crease in my rear guard over my tyre is there any way I can straighted it out. Can I use a heat gun or will this just harden
the plasics and make it break.
  • 2 weeks later...
it will take out the crease mark, but be real careful because yes if you melt the plastic it will eventually crack.
i tried a blow drier and it did a bit but not really. i didnt have a heat gun so i used a propane torch :shoothead: and it is real hard to control the heat with one of those and i melted it, ever so slightly, but chances are if you see it get glossy at all from the heat youve melted it, and it will probably break.
good luck
