The real fact of the matter is that any aftermarket pipe will be an improvment over stock, and if you are working with a budget, buy a pipe that your budget permits, you really can't go wrong with Toomeys, I had run Fattys for a couple of years and liked them but found them a little peaky, my personal fav are the Paul Turner Hi revs...the roll on soooooooooooo smooth and PULL, light weight and sound sick!. I am also a big fan of the rockets I run now the large chamber sounds like hell on wheels and power delivery is awsome!!
As for reed cages V-fore compared to a modded cage with PTR peddals.....I would take the modded cages any day of the week, not to mention put the 250$ differance into other parts on the Shee. :cool:
Cool thanks man.
I am leaning towards T5. As I have found a couple of sets that can be shipped to Australia. As for reed cages if there is only a minute power difference I will stick with the standard cages and change the paddles. I will also advance the ignition timing as hopefully she will be
sweet.
Has anybody got a similar setup. T5, K@N, paddles standard cages. I ride near sea level, what size jets and clips position should I start experimenting with?
On another note does anyone know how I can get a crease line out of my plastics over my rear wheel arch. I have heard a hairdryer or heat gun will do the trick any suggestions.
Cool thanks man.
sweet.
Any other opinions?
  • 3 weeks later...
Im gonna say the same shit I always do. Dont rule out DMC 916'S. Great all around pipe and have a sound like no other.
