tmac20031 Posted July 20, 2007 Report Posted July 20, 2007 I just dont know what will make it easier to steer so please dont give me any flack :biggrin: Anyways, Ive noticed that my cousins 450 steers a whole loy easier than the shee. What is it that makes it so easy to steer and what is the best mod? Quote
Nitmare67 Posted July 20, 2007 Report Posted July 20, 2007 450s were designed for girls. Banshee's for men. Buy a bowflex. Quote
tmac20031 Posted July 20, 2007 Author Report Posted July 20, 2007 450s were designed for girls. Banshee's for men. Buy a bowflex. Can I get a good answer from someone instead of a post boost. Quote
Hollister_Hitman Posted July 20, 2007 Report Posted July 20, 2007 yeah get +2+1 a-arms and a -2 swingarm. It will steer really easy after that Quote
Nitmare67 Posted July 20, 2007 Report Posted July 20, 2007 They steer really easy with 70hp or so and the front end hanging off the ground in 4th gear. Its like turning in air............ Quote
knight_ripper Posted July 20, 2007 Report Posted July 20, 2007 ALSO...on a serious note. you can replace the steering stem bearing....and loosen the clamp on the stem. also....you could get a steering dampner/stabilizer and that help's alot too. I put a GPR on mine....and it took away all my arm pump. Quote
tmac20031 Posted July 21, 2007 Author Report Posted July 21, 2007 yeah get +2+1 a-arms and a -2 swingarm. It will steer really easy after that Really, I figured it was maybe center of gravity but that cant just be it. ALSO...on a serious note. you can replace the steering stem bearing....and loosen the clamp on the stem. also....you could get a steering dampner/stabilizer and that help's alot too. I put a GPR on mine....and it took away all my arm pump. This is kind of the info I am looking for; something to do with the steering, rather than the layout of the bike. Quote
letsgetthisdone Posted July 21, 2007 Report Posted July 21, 2007 if you have fully adjustable aftermarket a-arms you can reduce the castor. this will make it steer more easily, but it will get twitchy if you reduce it too much.. Quote
91banshee Posted July 21, 2007 Report Posted July 21, 2007 take the top stem clamp off behind the radiator and greeze the stem real good and make sure the stem bearing is not locked up and air your front tires up a bit , it will steer just fine Quote
MX86 Posted July 22, 2007 Report Posted July 22, 2007 get a steering stabilizer. also check the wheels and see if they are aligned. Quote
