Big Blue Posted July 17, 2007 Report Share Posted July 17, 2007 Fast clutch kit w/ pandcake bearing, 1 trip to the dunes $90 pressure plate and inner hub $45 shippped shift forks rods, shaft all other parts except gears and drums $60 stock throttle $25 shipped billet case saver $15 Raptor clutch lever and cable $25 front calipers $30 rear caliper w/ block off $60 Quote Link to comment Share on other sites More sharing options...
Big Blue Posted July 17, 2007 Author Report Share Posted July 17, 2007 Also Stock cdi 45 stock coil 35 RS coil never used 45 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted July 17, 2007 Report Share Posted July 17, 2007 Fast clutch kit w/ pandcake bearing, 1 trip to the dunes $90 pressure plate and inner hub $45 shippped shift forks rods, shaft all other parts except gears and drums $60 stock throttle $25 shipped billet case saver $15 Raptor clutch lever and cable $25 front calipers $30 rear caliper w/ block off $60 i' ll take the case saver do you have the longer bolts also? are the calipers raptor also? Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted July 17, 2007 Report Share Posted July 17, 2007 What year is the cdi/coil? Quote Link to comment Share on other sites More sharing options...
Big Blue Posted July 17, 2007 Author Report Share Posted July 17, 2007 Yes I have the longer bolts, raptor is the brand of lever the calipers are off a 04 banshee. The CDI and coil are from a 04. Quote Link to comment Share on other sites More sharing options...
Fireroad Express Posted July 18, 2007 Report Share Posted July 18, 2007 if 375 doesn't take the case saver and coil, let me know cause i want them!!! PM me! Quote Link to comment Share on other sites More sharing options...
Big Blue Posted July 18, 2007 Author Report Share Posted July 18, 2007 UP!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted July 20, 2007 Report Share Posted July 20, 2007 UP!!!!!!!!! money sent for; R caliper, clutch lever & case saver Quote Link to comment Share on other sites More sharing options...
Big Blue Posted July 20, 2007 Author Report Share Posted July 20, 2007 Stock coil, rear caliper, clutch lever/cable and case saver sold. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted July 23, 2007 Author Report Share Posted July 23, 2007 ^^^ Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted July 23, 2007 Report Share Posted July 23, 2007 Do you have a throttle cable in your stash of parts? Quote Link to comment Share on other sites More sharing options...
Big Blue Posted July 31, 2007 Author Report Share Posted July 31, 2007 ^^^ Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted July 31, 2007 Report Share Posted July 31, 2007 parts look good Derek, thanks !! DAVE Quote Link to comment Share on other sites More sharing options...
Big Blue Posted August 1, 2007 Author Report Share Posted August 1, 2007 No problem. Quote Link to comment Share on other sites More sharing options...
