Banshee 79 Posted July 17, 2007 Report Posted July 17, 2007 I just bought a front & rear primary drive sprocket, does it matter which way the sprocket goes on? Thanks Quote
J-Madd Posted July 17, 2007 Report Posted July 17, 2007 It shouldn't matter at all on either sprocket if they're just like others. Never had primary drive sprockets, though. Quote
locogato11283 Posted July 17, 2007 Report Posted July 17, 2007 i dont think it really matters but i always run them with the numbers facing the left side of the bike.. so when youre looking at the front you can see the tooth number on it.. same way for the rear.. Quote
locogato11283 Posted July 17, 2007 Report Posted July 17, 2007 i dont think it really matters but i always run them with the numbers facing the left side of the bike.. so when youre looking at the front you can see the tooth number on it.. same way for the rear.. i run PD sprockets. they are good stuff. never had an issue with one. Quote
jmd0346 Posted July 17, 2007 Report Posted July 17, 2007 I just bought a front & rear primary drive sprocket, does it matter which way the sprocket goes on? Thanks The front doesnt matter. The only way the rear could matter is if it has counter sunk holes. Im not sure if any do but I guess its possible. My rear can go either way. Quote
