KaosBanshee44 Posted July 12, 2007 Report Posted July 12, 2007 I'm trying to remove my bearings out of my old hubs into some new ones. Thing is there are two bearings in the hub that fall into there on lip. I don't wanna go buy new bearings if i can use the old ones still cause there in good shape but the problem is getting them out of the old hub without damaging them first. Anybody ever taking them out or know ow to take them out.....Is there a certain tool you use? Quote
okbeast Posted July 12, 2007 Report Posted July 12, 2007 Piece of pipe and a hammer. Works everytime if it's the right size. Quote
FireHead Posted July 12, 2007 Report Posted July 12, 2007 A press always helps in this sort of situation as well. I am not sure reusing bearings is worth the hassle though. Bearings just are that expensive of a wear item. Quote
racer Posted July 12, 2007 Report Posted July 12, 2007 If you use the pipe method, I prefer a socket cause of their varying sizes, you probably won't want to reuse them. Chances are they will develop play in them from you beating on them, and that's no good mang. Quote
BenBB Posted July 12, 2007 Report Posted July 12, 2007 They are a bitch, expect lotsa cussing whilst trying to get that goddamn spacer cocked just right to get the first bearing out. If ya got new hubs I'd call a bearing store and find out how much they are, probably well worth not having to fight the old ones while being careful not to fuck them up...but you still need the spacer outta there unless the new hubs came with it. National part numbers for bearings are: Inner 6004 Outer 6202 Seals. (inner x outer x depth) Inner 22mm x 35mm x 7mm Outer 22mm x 35mm x 7mm So to do both front hubs you need to buy two of everything (cut & past I had saved). Remember to get good bearings not Chinese or Hindu (Japanese or German tend to be the best). Good luck. Quote
FireHead Posted July 13, 2007 Report Posted July 13, 2007 If you use the pipe method, I prefer a socket cause of their varying sizes, you probably won't want to reuse them. Chances are they will develop play in them from you beating on them, and that's no good mang. Word. The socket is always a better idea than a pipe/tube. :geek: Quote
KaosBanshee44 Posted July 13, 2007 Author Report Posted July 13, 2007 Yeah i made alot of calls today. there are some bearing that you can save "for example" the water pump impeller for instance....But for wheel hub bearings don't take the chance unless your a cheap bastard and wanna use the old ones. I ordered new ones from www.mcmart.com today there cheap as helll. Quote
okbeast Posted July 13, 2007 Report Posted July 13, 2007 Word. The socket is always a better idea than a pipe/tube. :geek: My piece of pipe is the perfect size :biggrin: Quote
FireHead Posted July 13, 2007 Report Posted July 13, 2007 My piece of pipe is the perfect size :biggrin: I am sure there is a penis joke to be made there, but I am not sure what it is. Quote
okbeast Posted July 13, 2007 Report Posted July 13, 2007 (edited) It's not the size of the boat that matters, it's the motion of the ocean Edited July 13, 2007 by okbeast Quote
racer Posted July 13, 2007 Report Posted July 13, 2007 (edited) I am sure there is a penis joke to be made there, but I am not sure what it is. maybe: why does your penis taper like a spindle snout? Edited July 13, 2007 by gimmeabeer Quote
okbeast Posted July 13, 2007 Report Posted July 13, 2007 maybe: why does your penis taper like a spindle snout? Is that even a joke, or are you going to tell us why Quote
FireHead Posted July 14, 2007 Report Posted July 14, 2007 Is that even a joke, or are you going to tell us why I don't think I want to know why. Quote
LiftdT4R Posted July 14, 2007 Report Posted July 14, 2007 Damn, just did like my 6th set of front hub bearings here, hahaha, bring'em to me and I'll do 'em for you for a case of beer. Alternatively, find a small brass punch, and work your way around the first bearing from the inside, it's a little tedious, but you should have a little bit of play in the spacer, enough to just catch the lip of the bearing with the punch. The brass punch won't damage the spacer, but for $35 on e-bay you can buy all front bearings, seals, and the back 2 carrier bearings and seals as well. You can also buy the bearing puller they talk about in the Clymer manual, but I'm not sure how much it costs or where to get it. :shrug: Good luck bro! Quote
KaosBanshee44 Posted July 17, 2007 Author Report Posted July 17, 2007 Well the bearing in the hubs are a bitch to get out so i just went ahead and ordered all new internal bearings for the new ones. It's hard to explain how the bearings are set in the hub on here but some know what i'm talking about. Quote
