dwrracing Posted July 12, 2007 Report Posted July 12, 2007 OK here we go guys please give me all the help u can as you guys have been a ton of help so far i got my banshee and a buddys banshee i just baught mine i have been racing mx on 4 strokes for the last 4 years so i am new to the 2 stroke game on his banshee we are on stock bore no porting i just got him a noss head with 21cc domes he wants to run pump gas i also got him a timing plate what should i set it to we are at sea leval i want to be safe with his??? also he has stock carbs with pro flo k&n filter were should i put the needle and pilot and main jet at a starting point? he has toomey t6 pipes??? ok on my banshee i just had rb racing do a dune port on cylinders noss head i got 19cc domes running race gas i also got timing plate what should i set it to??? i am getting inframe shearer pipes,with 2into1 38mm carb any help would be appreciated thanks guys!! Quote
knight_ripper Posted July 13, 2007 Report Posted July 13, 2007 i pretty much have the same setup as your buddys. I am running my timing plate at +4 advanced. also my main jet is an 062 and im on the second notch on the needle jet, idle screw 2 turns out. I run between sea level and 7000 ft with no jetting done. runs great at sea level....although I run 50/50 gas. Runs like sheet up at 7000ft...but I mosey along. I am however running Moose Needles. I had to switch over due to problems with the stockies. shee runs way better with the moose. I think they are tapered differently. hope that helps. not sure about your rid. I havnt steped into port and polish yet. I think the dome sizes directly affects gas tho. If I remember correctly ... if I was to go below a 21cc dome I would have had to run 50/50 all the time. go lower and your steping into 110 octane. Quote
Snopczynski Posted July 13, 2007 Report Posted July 13, 2007 OK here we go guys please give me all the help u can as you guys have been a ton of help so far i got my banshee and a buddys banshee i just baught mine i have been racing mx on 4 strokes for the last 4 years so i am new to the 2 stroke game on his banshee we are on stock bore no porting i just got him a noss head with 21cc domes he wants to run pump gas i also got him a timing plate what should i set it to we are at sea leval i want to be safe with his??? also he has stock carbs with pro flo k&n filter were should i put the needle and pilot and main jet at a starting point? he has toomey t6 pipes??? ok on my banshee i just had rb racing do a dune port on cylinders noss head i got 19cc domes running race gas i also got timing plate what should i set it to??? i am getting inframe shearer pipes,with 2into1 38mm carb any help would be appreciated thanks guys!! 38mm carb on 2 into 1 with stock type cylinders is gonna be too big of a carb. I dont recommend over a 36mm unless you get a big bore or cub cylinders. Quote
Snopczynski Posted July 13, 2007 Report Posted July 13, 2007 OK here we go guys please give me all the help u can as you guys have been a ton of help so far i got my banshee and a buddys banshee i just baught mine i have been racing mx on 4 strokes for the last 4 years so i am new to the 2 stroke game on his banshee we are on stock bore no porting i just got him a noss head with 21cc domes he wants to run pump gas i also got him a timing plate what should i set it to we are at sea leval i want to be safe with his??? also he has stock carbs with pro flo k&n filter were should i put the needle and pilot and main jet at a starting point? he has toomey t6 pipes??? ok on my banshee i just had rb racing do a dune port on cylinders noss head i got 19cc domes running race gas i also got timing plate what should i set it to??? i am getting inframe shearer pipes,with 2into1 38mm carb any help would be appreciated thanks guys!! 38mm carb on 2 into 1 with stock type cylinders is gonna be too big of a carb. I dont recommend over a 36mm unless you get a big bore setup or cub cylinders. Quote
Snopczynski Posted July 13, 2007 Report Posted July 13, 2007 38mm carb on 2 into 1 with stock type cylinders is gonna be too big of a carb. I dont recommend over a 36mm unless you get a big bore setup or cub cylinders. Quote
blowit Posted July 14, 2007 Report Posted July 14, 2007 38mm carb on 2 into 1 with stock type cylinders is gonna be too big of a carb. I dont recommend over a 36mm unless you get a big bore setup or cub cylinders. The 38mm is a good size for you. If you are going to ride at any altitude, the bigger carbs help keep power up and you can absolutely tune a 38mm to grunt like a pig in heat on the bottom. Brandon Quote
dwrracing Posted July 14, 2007 Author Report Posted July 14, 2007 yea we will see if it works good!! i am in florida so i am at sea leval and its always hot down here Quote
Snopczynski Posted July 14, 2007 Report Posted July 14, 2007 we ran a 38mm lectron on a 4mill stroker at sea level and it had way better throttle response and power with a 36mm lectron. Quote
blowit Posted July 14, 2007 Report Posted July 14, 2007 we ran a 38mm lectron on a 4mill stroker at sea level and it had way better throttle response and power with a 36mm lectron. The performance of the 38 is very dependent on engine setup and jetting. Doing the numbers, the 38 is a better choice, especially for a stroker. Not sure why your power was falling off with the 38 but should work great. Did YOU port it? If porting is out of the bubble, you may very well have to run a smaller carb to mask port timing issues. Just a thought. Brandon Quote
