Well i just put in a 404 big bore kit for my 2003 Banshee everything went great it even started up on the 4th or 5th kick but my question to you all is what is my jetting needing to be it was 260 and i moved it up to 300 is that enough or do i need to go more? Another question is how do i check if it is to lean or rich. Last question is only one of my pipes is smoke heavy smoke the other is real light what or why is it doing that both vent hoses are connected and the air screws are the same. Any answer will help
so you have stock carbs? you had the sleeves pressed in your cylinders or what? you need to be more specific and give more details.. you need to do a WOT plug check and see what your plugs look like to determine your jetting.. what pipes? what air filter setup? we need more info.
Well i have stock carbs and i did have the sleeves pressed into the jugs. only thing is now i got the pipes to smoke equal and now its just jetting i have fmf fattys and a k&n air filter on it, it runs fine but i dont know how to run a wot check on it is 3rd gear wide open and shut off and check or is it 6th gear
Abc...123...
http://www.dfn.com/benkaren/plugchop.html
