I am looking to order some new tires but sticking with the stock rims on my 05 LE. What size can I go, any thing you can give me would help. Thanks
Edited by ZachBreck
in the back you can get anything with the lant numbers 11-9 the stock tire size should be 20-11-9
the first number ( in this case 20'' ) is the tire diameter the 2 number ( in this case 11" ) is the rim withes the 3th number ( in this case 9" ) is the rim diameter
the same for the front
the front is anything with the last numbers of 7-10 the stock tire size should be 21-7-10
i wod suggest front 21-7-10
rear 20-11-9
hope this helped you
