Whats the biggest bore size that I could bore my cub out too its 68mm right know I need to if I could go bigger or if I should stay the same ? And what company should I have do the work? THANKS
If you can clean it up, stay where your at... if not, only go as far as neeeded not worth the waste of future bores, you won't gain any noticeable HP
yea, stay with what you got unless you have to bore it. never know when you might need the clearance later if you smoke it in a major way... being a cub it should have a nicasil lining so you can usualy just wipe the bore's down with some muratic acid and your good to go again...
