rhuebner Posted June 24, 2007 Report Share Posted June 24, 2007 Sup fellas I recently rebuilt my shee (stats in sig) I have only ran 1 tank of gas threw it but it has absolutly no power band. Why? prob jetting i'm running 35mm keihin airstriker carbs with 160 main, 48 pilot. My timing is at +7 and I also have a degree key is +7 to high? any help would be greatly appriciated. Thanks. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted June 24, 2007 Report Share Posted June 24, 2007 Sup fellas I recently rebuilt my shee (stats in sig) I have only ran 1 tank of gas threw it but it has absolutly no power band. Why? prob jetting i'm running 35mm keihin airstriker carbs with 160 main, 48 pilot. My timing is at +7 and I also have a degree key is +7 to high? any help would be greatly appriciated. Thanks. 7 on the plate & 4 on the key, or 3+4, 7 total Quote Link to comment Share on other sites More sharing options...
rhuebner Posted June 24, 2007 Author Report Share Posted June 24, 2007 7 on the plate & 4 on the key, or 3+4, 7 total Doesnt the key ad 2 with my 7 on the plate thats 9 right? is that to much? maybe 5 on the plate with the 2 on the key Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted June 24, 2007 Report Share Posted June 24, 2007 Doesnt the key ad 2 with my 7 on the plate thats 9 right? is that to much? maybe 5 on the plate with the 2 on the key mine is 4*( don't know if they make A 2*), probably not your problem but you should bouble check it you go any higher Quote Link to comment Share on other sites More sharing options...
