Sup fellas I recently rebuilt my shee (stats in sig) I have only ran 1 tank of gas threw it but it has absolutly no power band. Why? prob jetting i'm running 35mm keihin airstriker carbs with 160 main, 48 pilot. My timing is at +7 and I also have a degree key is +7 to high? any help would be greatly appriciated. Thanks.
7 on the plate & 4 on the key, or 3+4, 7 total
Doesnt the key ad 2 with my 7 on the plate thats 9 right? is that to much? maybe 5 on the plate with the 2 on the key
mine is 4*( don't know if they make A 2*), probably not your problem but you should bouble check it you go any higher
