Hey,
I've been gone a while moving, studying, you name it.....
I have a 4 mil cub set up with drag ported cylinders, crank, pistons with wrist pins and rings and base gasket.
I bought it brand new and never installed anything, it sat on the bench being lonely and since I've not used it by now, I'm selling it. $1200 for the setup and I think I have two extended studs and a new max load bearing that should go with it huh? :biggrin:
I have a complete lockup clutch, polished cover w/ blue lexan, new fibers, hub, basket, basically every clutch component with a pancake bearing, shift shaft assembly, seals and perhaps some things I've forgotten about that I should have gotten rid of by now, but haven't. All brand new in the box and never installed....they sat on the bench and kept the cylinders/crank/pistons company.
I also have an 01 that I stripped down to the bare frame to paint which is now boxed up and in storage that I'd like to get rid of. It's complete minus the swing arm and the pistons&rings which I tossed when I took the motor apart. They were in good shape and the cylinders are bone stock and in great shape however I didn't plan on putting used pistons back in so they were tossed. I've got a few aftermarket parts with it....
VForce3 reeds
Pro Design air cleaner setup
Aluminum bumper, AC or DG, I don't recall
DG nurf bars
Renthal bars
Studded for ice stock rear tires, tracker paddles and new holeshots front and back, all on rims
FMF fatty pipes
Billet pipe clamps
Dynojet kit
K&N filter...I took off and installed the Pro Design
I have no doubt that I've forgotten a few things and I'd like to sell this as a basket case just because it'd be easier even though I know I could simply part it out for more $$ but just take the whole thing and I'm sure we can come to an acceptable agreement now.
I don't get on the forums as much as I'd like anymore so give me a call and we can talk.
Cell 734-717-6572
Day 248-587-1175
I'm Howie and I'll talk to you later....
