shee4speed Posted June 17, 2007 Report Posted June 17, 2007 Hey guys I just removed the bowls off the carbs and realized one of them does not have that little tube in there. Is this thing necessary or just for alignment? Thanks. Quote
shee4speed Posted June 17, 2007 Author Report Posted June 17, 2007 I meant to say the little tube mounted in the bottom of the carb that lines the bowl up.Anyone? Quote
blak banshee Posted June 17, 2007 Report Posted June 17, 2007 its normal, thats the way they come Quote
shee4speed Posted June 17, 2007 Author Report Posted June 17, 2007 oh okay I wont worry about it then. Thanks Quote
blowit Posted June 18, 2007 Report Posted June 18, 2007 oh okay I wont worry about it then. Thanks Good idea to leave it. that is your overflow protection. If the float level exceeds the top of that tube, it will dump on the ground rather than filling your engine with raw fuel. Brandon Quote
shee4speed Posted June 18, 2007 Author Report Posted June 18, 2007 The little tube mounted in the bottom of the carb.Not the one in the bowls.Only one of the carbs has it? Quote
