milo_32000 Posted June 12, 2007 Report Posted June 12, 2007 I pulled carbs off to clean them because shee was running like ####, the right carb has NO nipple to connect the choke tube hose, am I correct in thinking it {had } a nipple in the right carb to connect it ? If it did where can I get one ? Thanks guys , everyone has always been great help on this forum. Milo_32000 Quote
Snopczynski Posted June 12, 2007 Report Posted June 12, 2007 Stock carbs? You didn't put them on switched around did you? The nipple is right acroos from where the left one is, that tube just fits straight in there. Quote
mybadbanshee Posted June 12, 2007 Report Posted June 12, 2007 you probably have them in backwards, the nipple is cast right into the carb. Quote
milo_32000 Posted June 12, 2007 Author Report Posted June 12, 2007 The left carb has the pull knob for the choke, I just looked at the right carb, it has a threaded hole on the left side of it , it looks as if it had a nipple in it , but I`m not sure, Thanks for the help, I need it ,,, Milo Quote
milo_32000 Posted June 12, 2007 Author Report Posted June 12, 2007 Thanks for the help of Snop & Mybad , I`m the DUMB ASS of the week, I had the right carb in reverse, I have looked at it for 2 hours, Thanks everyone, this forum is GREAT, milo_32000 Quote
pokeatyou2 Posted June 12, 2007 Report Posted June 12, 2007 gez if you had the right carb on backwards you must of had one hell of a time getting the bell end of the carb into the intake manifold Quote
mybadbanshee Posted June 12, 2007 Report Posted June 12, 2007 Thanks for the help of Snop & Mybad , I`m the DUMB ASS of the week, I had the right carb in reverse, I have looked at it for 2 hours, Thanks everyone, this forum is GREAT, milo_32000 lol, happens to the best of us. Quote
Dinner Posted June 14, 2007 Report Posted June 14, 2007 gez if you had the right carb on backwards you must of had one hell of a time getting the bell end of the carb into the intake manifold :ohmy: Hopefully he didn't rip the rubber or crack it...I doubt he wants any lean leaks after this... Quote
David Keith Posted June 16, 2007 Report Posted June 16, 2007 :ohmy: Hopefully he didn't rip the rubber or crack it...I doubt he wants any lean leaks after this... Right on. Better to check for any possible leaks before starting it again. Rubber boots only stretch so far. Quote
