Isnt that a shift shaft seal? Just pull the shift shaft, and replace the seal. I think thats all there is to it.
Yep, never had a leak there but theres a seal on it, that should do the trick :thumbsup:
Eric
its a very easy fix and you can buy the seal on ebay for like 3 bucks.
Am i retarted? Cause i cant find the seal on ebay, tried to when i first saw this post...
:blink: <== Me
Eric
You can change the seal without removing the shift shaft. Drain the trans. fluid and remove the left foot peg, shifter and stator cover , make sure the shift shaft is really clean,screw a couple of drywall screws a couple of rounds into the old seal and pull it will pop right out .Grease up the new seal slide it on and push it into place...
Edited by MDS2106
