peterlocal22 Posted June 8, 2007 Report Posted June 8, 2007 Hello, Im from the New England area and I had rocket pipes but im changing over to Toomey T5's. My set up with the rockets is as follows: Toomy T5's, Delta V Force Reeds, 310 main jet, Adj. timing plate, Uni Filter w/ Pro Flow Plate. Do i need to change anything like the jetting when i switch to the t5's or am i good to go? thanks Quote
375hp banshees Posted June 8, 2007 Report Posted June 8, 2007 Hello, Im from the New England area and I had rocket pipes but im changing over to Toomey T5's. My set up with the rockets is as follows:Toomy T5's, Delta V Force Reeds, 310 main jet, Adj. timing plate, Uni Filter w/ Pro Flow Plate. Do i need to change anything like the jetting when i switch to the t5's or am i good to go? thanks every bike is different, do A plug chop. Quote
Toomey Banshee Posted June 9, 2007 Report Posted June 9, 2007 You should be about right. I'm pretty sure I ran 300's with no lid, pro flow plate and a foam dual stage filter on my 99 with T-5's. BTW, why did you switch out the Rockets? What did you do with them. Did you like them? Quote
